So positive update regarding PC rear RG. I got the replacement 12" AAM rear rock guard in on Friday, went and put it on this morning.
Fits perfectly!...
However, when I removed the factory bolts (mind you this is the second time they have been out) the lowest center and the lowest on the drivers side started to let gear oil leak out - no through the bolt holes but through the bottom of the cover.
Only a few drops, but I quickly got the RG mounted up, and actually started threading the lowest bolts first hand tight to try to get the dripping to stop. Then went back with the allen key and criss-cross tightened them down. This is what it looked like before I wiped it off:
Took it for a 30 minute drive after wiping it off. Unfortunately it is still ever so slightly seeping out at the bottom. Has anyone else ran into this? Should I just keep an eye on it for the next few days and see if it keeps seeping out?
I did not put locktite on the new bolts when I put them in, but I did that with my front RG and it was fine, still tight, no drips or seeping.
Is it possible I snagged the rubber gasket with one of the bolts when I put them back in when messing with the 11.5" RG? If I did, I would think it would've been seeping after that if that was the case.
Also, I did this rear RG when the axle was completely cold this morning, whereas the front RG and the incorrect 11.5 rear RG attempt was done when the axles were slightly warm, at the time I had just driven it like 20-30 minutes prior.
Any suggestions?
