Rear seat load floor
ski
I recently purchased a 2021 Ram 2500 Tradesman with a one piece rear bench seat. I would like to install Mopar's folding under seat load floor, but the only one made is for the 60/40 split rear seat. The two part numbers are, 6YA06TX7AA (60%) and 6YA07TX7AA (40%). No help from dealership and could not find any info on line. Will these two part numbers work on this vehicle, or can they be modified to work. The truck vin number is 3C6UR5HJ4MG681550. Thanks for any info that is available.
I won’t be very much help I don’t think but the other day while searching Amazon for accessories for my 2021 2500 longhorn, I saw one of those load Floors. You might try there, I think it was around $300. I don’t have a link.
Thanks, I'll take a look.
I haven't found it at Amazon, but if you see it again please send me the link. Thanks.
I think this is what he may have seen. It looks to be made from plywood and looks cheaply made but who knows. Why can't you just purchase the Ram one and install it, is it due to no mounting points in the middle due to the 60/40? If you look there may be hole for the bolts possibly.
I found this link you should look at to, maybe you can message them and ask them how they did it.
Somebody wants to pay shipping… you can have this one
I pulled it from my 2019 when I traded it in. I have the piece that I was going to use to connect it to my seat, but never used it.
I probably still have the plans someplace. I got them from a guy on here I think.
They will work but you will need to go wrecker diving and get the brackets / hinges / bolts from a truck that has them. The spots are there for you to just bolt and go (they may be covered by carpet and need to be cut out). You can use the hardware from a 1500 as long as it is the old 4th gen truck (ie classic) or a 2500. Because it is just the brackets you are using, it doesnt matter if it is a crew or quad cab (the crew have slightly longer load floors). Side note, take a breaker bar with you to the wrecker ... removing seats is not fun when the truck is not new
I found plans for one somewhere on the internet and built it for my 2017 Big Horn. It was pretty easy to build and it lasted until I traded it in for my 2019, it was perfect for my dog to stand on, in fact it was stronger than the one that came stock in my 2019 Longhorn 3500.
IF you want to keep it flat always, I had a 1500 and the back is for the dogs so I needed the fold flat but it didn't come with the truck. So, I got a piece of OSB and cut it resting the back on the seat supports. It worked great had lots of storage underneath for dog stuff or emergency gear etc. It was better than factory. I custom cut it. I could have seated the posts better, but once in worked fine. 20210719_085223.jpg
