I have a 50 gallon Lund vertical tank that sits below the rails and works with my Demco. It is 60” x 12”, works great in the 6’ 4” bed.This is what I did for my 33 Gal. tank on my 18 SB. I had the Pullrite 2700 Slider. View attachment 31952 Used 6x6 to raise it for clearance for the rails.
We’re you using a curt / mopar slider ?I’ve seen where many have talked about different tanks but no one has mentioned the RDS 74736. It is a 50 gallon tank, it sits below the bed rails and you can still use the puck system on the 6’4” bed with a Curt/Mopar fifth wheel mount.
I have this tank installed on my truck.
View attachment 31940View attachment 31939View attachment 31938
I was using a Curt A16, non slider. I have since switched to a Anderson hitch as it is way lighter but really because it is much easier to connect on uneven ground as I basically only boondock.We’re you using a curt / mopar slider ?
Gravity fed by Teeing into the filler neck. RDS kit 11408.How is this plumbed to your fuel tank?
Do you have any pics of the tee installed on your truck ? ThxGravity fed by Teeing into the filler neck. RDS kit 11408.
Is this Diesel or Gas? Have you filled that tank yet...Iam wondering if it will run out the filler neckGravity fed by Teeing into the filler neck. RDS kit 11408.
