Great White North Eh
Squish Cat - And So
Ain’t no car company’s given a crap about the consumer … pick yer poison and drink away!
I just purchased a brand new 2024 Ram 2500 Mega Cab 6.7L & it sounds like I have the same issue. My truck has been at the dealer for 2 weeks & they can’t fix it. Did you ever get your truck fixed?I have had this issue since I purchased my Truck new. 2020 RAM 2500 Mega Cab 6.7L. I took it in to dealer with 2K miles, before the TSB came out about the cab mounts. This first visit, I was told "all the new models sound like that" not a month after the first service visit the TSB comes out for cab mounts. Three different dealerships have replaced the cab mounts and body isolators 3 separate times. The first time they broke the tabs on the nuts that support the mounts and the truck had to be taken to a body shop for repair. FCA hasn't been much help at all. None of these fixes worked. Every time I would take the truck in, I would get the "We couldn't reproduce the noise" BS. each time I made sure to take the tech for a ride and produce the noise and each time the tech would say "Wow that's horrible". The tech could see the origination of the noise with their pico scope or electronic ears and verified by driving that the noise is still present. I was told by FCA yesterday that there was nothing else they could do and that I needed to take it up with the dealer. I have fought this for a solid year and a half, at this point I think FCA's only job is to provide stall tactics until my warranty expires. I saved my hard earned money for years to purchase this truck, which I love except for the incessant rattle. I paid full price, I should get a new trouble free vehicle. In total my truck has been in the service shops for over a month and a half, and still no resolve. I have had enough frustration and will be looking into pursuing the lemon law.
Is your fix still working? My 2024 Ram 2500 has been at the dealer for 2 weeks for the same soundI had 8000 miles on my 2019 2500 6.4 4x4 when I purchased it, the truck rattled & clunked when I went over washboard sections from day one . I recently saw the Ram 2500 YouTube video showing the rear cab mount rattling when hitting washboards I noticed the cab mount bolt seemed too long allowing the mount too jump around causing the rattling. I came up with a home grown fix by removing both rear cab mount bolts and the big black washer also and placing some heavy rubber matting between the cab mount and the big black washer on both rear cab mounts and retorquing bolts back to 85 ft pounds. By doing this I took away the gap between the washer and the mount not allowing the mount to jump up and down over rough surfaces
, no more clunking now if I could only figure out how to stop the Squealing noise on cold starts I would be a happy camper!
I just bought a 2024 2500 and am having a clunk, rattle while going slow over certain bumps - sounds to me like front right suspension from inside the cab but at times sounds like its coming from the right rear... Is this similar to what you are hearing? Been at the dealer a few times so far and they are stumped.Is your fix still working? My 2024 Ram 2500 has been at the dealer for 2 weeks for the same sound
I hunted for this for a couple of months. It started as kind of a shudder/rumble/growl when shifting into 3rd gear under a load. I was starting to think it was a problem in the Aisin. I had a tech ride with me and he thought it was coming from the firewall in front of the passenger side. I finally thought it might be the stand pipe/heater hoses going through the firewall. I put a zip tie just slightly snug around them to keep them from vibrating and Eureka, the noise is gone. Guess I'll try to keep her for another hundred thousand miles.found my rattle noise, finally... the coolant stand pipe seems to vibrate excessively which causes the heater hoses to carry those vibes through the firewall, which makes it sounds like it's coming from inside the dash. finally!!!
glad that helped ya out!I hunted for this for a couple of months. It started as kind of a shudder/rumble/growl when shifting into 3rd gear under a load. I was starting to think it was a problem in the Aisin. I had a tech ride with me and he thought it was coming from the firewall in front of the passenger side. I finally thought it might be the stand pipe/heater hoses going through the firewall. I put a zip tie just slightly snug around them to keep them from vibrating and Eureka, the noise is gone. Guess I'll try to keep her for another hundred thousand miles.
Do you have a picture of where you put this zip tieI hunted for this for a couple of months. It started as kind of a shudder/rumble/growl when shifting into 3rd gear under a load. I was starting to think it was a problem in the Aisin. I had a tech ride with me and he thought it was coming from the firewall in front of the passenger side. I finally thought it might be the stand pipe/heater hoses going through the firewall. I put a zip tie just slightly snug around them to keep them from vibrating and Eureka, the noise is gone. Guess I'll try to keep her for another hundred thousand miles.
I have a 2022 Ram 2500 Tradesman. I thought the same with mine and after many days at dealership and many parts replaced it never went away. I did eventually find it.Update: This is the dealer fix that was done to my truck so far so good
Per the receipt from Ram, says see service supervisor, there are sop parts, contacted Chryslers Field Tech about concern, advised to replace rear cab mount with updated cab mount design.
QTY 2 68402173-AD Isolator 23043013
Thought I saw this posted up somewhere but couldnt find it. Truck is a 19 4x4 Ram 2500 Diesel. Any small jolt to the truck while driving, theres a rattle which sounds like its coming from the back somewhere. Ive tried folding the seat up and down, banging on stuff to see if i can hear the sound. tried buckling up the seat belts but nothing. Finally took it off pavement yesterday, and the sound is horrible. Anyone else experiencing this? I figure ask here before taking it in, and the dealer keeping my truck for a day and saying its normal.
Also the truck once in awhile makes a consistent 3 tick sound from the engine compartment. I feel like it only does it when its cold. But it doesnt always make the sound. Kind of mad at the dealer, I was down the street from the dealer and it started doing it. So i pulled up to the service department and asked the tech to come out so he could hear it, and said no and i need to make an appointment. ( Really grinds my gears how lazy people are, and how ****ty customer service is. Youre getting paid to do a job, do your job.)
