Andya96167
I'm having issues hooking up to a load. If I'm not dead center with the pin and move in very slowly I'm getting a partial lock - takes several attempts - any ideas what is going on?
Is the hitch well greased and well lubed inside on the springs and pinsI'm having issues hooking up to a load. If I'm not dead center with the pin and move in very slowly I'm getting a partial lock - takes several attempts - any ideas what is going on?
YesIs the hitch well greased and well lubed inside on the springs and pins
Any broken springs or weak springs in it? Can you close the pin lock manually?Yes it is
I can close the pin lock manually without a problem, I'll clean the hitch just to be sureAny broken springs or weak springs in it? Can you close the pin lock manually?
Any large amounts of dirt in the hitch head or perhaps excessive grease?
So if thats the case its a weak/broken spring or plugged upI can close the pin lock manually without a problem, I'll clean the hitch just to be sure
I'll clean the hitch first then look at the springs - thanks for the helpSo if thats the case its a weak/broken spring or plugged up
Most people dont know they can just hit the watch button instead of commenting to subscribe to the treadDumb question time - what is the point of posts that just say following? Why does everyone need to know you are following this? Genuinely curious if it has a function.
It is usualy just let the OP know that someone else is or had the same problem and is also looking for a solution and they'er not alone in experiancing the problem. That's the simple answer.Dumb question time - what is the point of posts that just say following? Why does everyone need to know you are following this? Genuinely curious if it has a function.
Its the method I know to follow the updates added to a thread I am interested in. That's all. I did not do so to advertise "look at me I'm involved also". And by doing so, I've just learned that there are other ways to follow a thread.Dumb question time - what is the point of posts that just say following? Why does everyone need to know you are following this? Genuinely curious if it has a function.
If the hitch pivots it doesn’t lock in, especially if too gentle. Had the same issue. Need to be square, centered, correct height, it gets easier. The center line on the cargo camera can be adjusted, see manual. The plate on the trailer needs to be slightly below hitch plate so it pushes the bed down slightly. When unhitching I had a problem being able to release handle after backing trailer into place. Cured by putting into neutral to release pressure then back to park.I'm having issues hooking up to a load. If I'm not dead center with the pin and move in very slowly I'm getting a partial lock - takes several attempts - any ideas what is going on?
