Ram 25 Fifth Wheel Hitch
Andya96167
I'm having issues hooking up to a load. If I'm not dead center with the pin and move in very slowly I'm getting a partial lock - takes several attempts - any ideas what is going on?
Is the hitch well greased and well lubed inside on the springs and pins
Any broken springs or weak springs in it? Can you close the pin lock manually?
Any large amounts of dirt in the hitch head or perhaps excessive grease?
I can close the pin lock manually without a problem, I'll clean the hitch just to be sure
So if thats the case its a weak/broken spring or plugged up
Dumb question time - what is the point of posts that just say following? Why does everyone need to know you are following this? Genuinely curious if it has a function.
What's your trailer pin box height in comparison to your hitch height when connecting?
It is usualy just let the OP know that someone else is or had the same problem and is also looking for a solution and they'er not alone in experiancing the problem. That's the simple answer.
  • Like
Reactions: CFE
Its the method I know to follow the updates added to a thread I am interested in. That's all. I did not do so to advertise "look at me I'm involved also". And by doing so, I've just learned that there are other ways to follow a thread.
If the hitch pivots it doesn’t lock in, especially if too gentle. Had the same issue. Need to be square, centered, correct height, it gets easier. The center line on the cargo camera can be adjusted, see manual. The plate on the trailer needs to be slightly below hitch plate so it pushes the bed down slightly. When unhitching I had a problem being able to release handle after backing trailer into place. Cured by putting into neutral to release pressure then back to park.
Just an FYI he had another post stating its a 2014 and he hotshots so im sure he knows how to hook up a trailer when the hitch works properly…
Hmm, new member, 6 posts, simple question, guess I should have known. I will have to be more careful in the future. You wouldn’t know when he had his last colonoscopy by any chance.
