Actually, heat can be applied via conduction and convection just as well in liquids. A stick on heater has to heat the heater element, and then the oil pan, and then finally the oil pan heats the oil. Furthermore, the heater element is exposed to frigid air on one side even after it increases temperature. A block heater heats the element, and then directly heats the oil. The element is not exposed itself to anything except for oil - so it's efficiency (while not 100% due to the variable of the actual block temperature) will be higher than the stick on heater. Both will work. I believe the block heater will be more effective given convection in liquids is very effective - and it's completely protected (unless of course you don't unplug it before driving - lol.) Just making the point that when dealing with fluids, it's not as simple as heat rising.I bought a 250w stick on oil pan heater for my truck. Less engine wear, faster warm up, I’ve installed them on all my 5.9 L trucks previously. Heat rises BTW.
I should probably also mention that I believe that the block heater is 750 watts? So 3x the power in theory of the stick on heater.
