It written 1,498 lbsI have a 12k 5th wheel and the pin weight is 2k lbs. I went with a 3500 for this very reason.
What is the pin weight of your 5th wheel?
Then you should be fine. The payload and towing are both beneath your limits.It written 1,498 lbs
Thank you very much. And with Rambox the width of the bed box is 50’’ do you think I’ll be fine?Then you should be fine. The payload and towing are both beneath your limits.
Thank you very much. And with Rambox the wido you thinkThen you should be fine. The payload and towing are both beneath your limits.
And with Rambox limited the width of the bed box of 50’’ Do you think it’s a problem?Thank you very much. And with Rambox the wido you think
That will be dry weight. I bet loaded down with all camping gear, propane, batteries and any on board water you want to carry, you will be solidly north of 2000 pounds of pin weightIt written 1,498 lbs
I had a F-150 Ecoboost 3,5L, so I’m sure I’ll see the difference qui my Ram 2500.Um, that's gonna be dry weight.
Add passengers (drive is already factored), gear, hitch, you're gonna be over.
18-20 GVWR is more realistic. A toyhauler with a full garage may be a tad lighter on the pin. My RV is 11,995 and the pin runs 2100 or so loaded up.
That said, legalities aside, lots of folks run their 2500 over payload.
Good decision I think.So finaly, I cancelled my order of the 2500 and go for 3500 with a payload of 3740 pounds.
are those options you requested or came with the truck?Finally got My new Ram 3500 Laramie Sport edition. Everything is perfect, Payload is close to 4k lbs and Max towing of 19000lbs. What thing I was surprised to see, or not see I should say, is I don't have the Navigation option and all the phone options with unconnect app.
Came with the truck.are those options you requested or came with the truck?
on the payload there is a website that will confirm based on VIN. and there is also a thread that you can share and check payload details.
Please Post Payload Sticker from Driver's Door Jamb.
Okay, finally found a 2500 Limited near me that I could drive and view the payload sticker. The news is just awful; 1,990 lb payload. 2019 RAM 2500 SRW 4x4 Limited Crew Cab 6"4" Bed +Delmonico Red, $100 +Towing Tech Grp, $445 +Protection Group, $95 +5th Whl/Gooseneck Towing Prep, $445 +Body...hdrams.com
Is it something I can order and add?Finally got My new Ram 3500 Laramie Sport edition. Everything is perfect, Payload is close to 4k lbs and Max towing of 19000lbs. What thing I was surprised to see, or not see I should say, is I don't have the Navigation option and all the phone options with unconnect app.
Prelim answer is yes/most likely depending on how far down the rabbit hole.Is it something I can order and add?
