Opinion on Ram Boxes - 2025
Thanks for sharing - def not what I wanted to hear but still appreciated.
To be clear this is not the norm, but it does happen. Mine has had a slew of bed related issue, Ramboxes, bed out of alignment, tailgate not closing correctly.
A buddy has them on his 3500. They feel cheap to me, like they should only be offered on 1500s. He's not happy with them, some of the warping and seal problems. I get that they offer a bit of conveniences for some uses. Personally I don't see the value. If I wanted to give up that much bed space, why not just get a chassis cab, put on a flat bed, and mount metal boxes? Wouldn't be as pretty, but it would be more secure, with more options.
Well depending on the purpose and usage that would be an option. Ramboxes actually have lots of value when used within the intended purpose, the need to carry lots of smaller stuff needed to access easily. I've seen many trades people using them when a bigger truck is not necessary. In my case I got this truck for one purpose pretty much, to tow our trailer. The Ramboxes hold all our small stuff we use camping frequently as well as a small air compressor, 18V drill & batteries, emergency kit, 3 ton scissor jack, hitch stuff, cleaning stuff, fishing poles occasionally, etc. I rarely carry much in the bed except an occasional run to Home Depot. In four years the truck only has 30K on it so a chassis cab would be serious overkill.
I really like them! Have them in my '14. It's where all the groceries etc. go.
I had a 2015 1500 and now a 2023 2500 both with ram boxes. I would prefer to never have a truck without them. They are extremely useful.
As mentioned you can still carry full size 4*8 sheets in the bed you lose a little bit of space overall going to the boxes but it is sooo nice to not need to reach over the side to get stuff you need that would be in the bed. You just pop open the box and it's all right there.
I carry everything from a spare set of tools, a fire extinguisher (full size), recovery straps, tie down straps, air compressor and a jump starter in them and still have room.
I had a small issue on the 1500. The actuator on both boxes died about the same time about 80000 on the truck. Easy fix.
Good luck
I've never had them but am sure the extra storage is useful. Just think they look sort of weird but that's me.
