johnmyster
Perplexing, conundrum, with 3/4 of a quart sitting on the head, it makes it hard to check the oil with the level of accuracy that this thread demands from a dipstick. If this motor is that picky, better not drive around turns or on hills. Might go beyond catastrophic minimum or maximum in the sump. Foamtella here we come.and on this engine it’s 1/2-3/4 quart based on what stays in the head and the pan. 3 gallons gets most engines to the top of the full level and is easy, so that’s what people do.
The reason for the 30 minute mention is the same as the 30 minute drain when changing the oil,
Good thing I change oil after being parked overnight. Looks like 3 gallons actually is the right number for me. Explains why it nails the dipstick range. Low end right after running. High side after sitting overnight. “At least” thirty minute drainback, somewhere in the middle. Golden. It’s almost as if they designed it that way.
