Rockcrawlindude
a rock crawlin’ dude
That’s a good kit.I picked up a smitty built winch accessory kit. Straps, tree strap, shackles, pulley. Looking to get a receiver shackle set up for the rear.
This has been helpful. I need to put something together to keep in the truck. For my needs though I'm not going to do any rock crawling or even backwoods. My biggest issue is going to be in the snow or maybe a muddy ditch. Maybe this Smittybuilt kit and some traction racks would meet my needs.I picked up a smitty built winch accessory kit. Straps, tree strap, shackles, pulley. Looking to get a receiver shackle set up for the rear.
Traction boards and GOOD shovel are king in the snow! Plastic shovels and little e-tools are convenient but suck when you need to do a lot of digging.This has been helpful. I need to put something together to keep in the truck. For my needs though I'm not going to do any rock crawling or even backwoods. My biggest issue is going to be in the snow or maybe a muddy ditch. Maybe this Smittybuilt kit and some traction racks would meet my needs.
Good points!Most of you don't have recovery points in the rear and need something like the below. Don't forget the adaptor for different size recievers (if another vehicle with a smaller reciever needs to recover you!).
Even with my AEV rear bumper I still carry the below in case I need to be recovered by someone that doesn't have rear recovery points.
Photo credit to @Rockcrawlerdude
Thanks for the mention, @AnthonyD1978Most of you don't have recovery points in the rear and need something like the below. Don't forget the adaptor for different size recievers (if another vehicle with a smaller reciever needs to recover you!).
Negligible. A decent recovery bag weighs less than a sturdy gal passengerJust curious, what do you think the impact of the large gear load outs are on MPG?
Interesting…high lift Jack + rock sliders works good at breaking beads as well, if already have one of themI found out about a new tool today while helping a buddy today. I’m adding one of these to my truck/trail kit. Bead buster 452
Yeah, I’ve used that method and also just running over the tire with another rig (usually what I do) while there is nothing wrong with those methods, i see the benefit of this little thing. Your hi lift jack may be in use if you’re breaking down a tire, and running over the sidewall may be undesirable in mud or other situations. I have a hilift on my Toyota but not in my ram.Interesting…high lift Jack + rock sliders works good at breaking beads as well, if already have one of them
Carrying Hi lift jack is pretty useless on a HD Ram anyway. No lifting points you can use safely unless you have white knuckle sliders.My recovery kit includes:
30ft x 1" Freedom Recovery Kinetic Rope
2x 1/2"x7" Freedom Soft Shackles
2x 5/16"x5" Yankum Soft Shackles
10"x3 Tree Strap
12k Snatch Block
Hitch Attachment with 3/4 shackle
Tool kit with power tools
Tire repair kit
Ridgid cordless tire inflator
I don't carry a hi-lift or any jack because whomever I wheel with has one (mainly hi lift). Currently in search of a jack that uses a socket to work so I can just use an impact.
Toyota has one, though.
And then you can’t change the tire. Smart.This....
Hi-Lift Lift Mate Wheel Attachment
Plastic bumpers and extreme lift-kits are no longer a problem. Many trucks and SUV's have larger tires and/or lift kits that require extensive lifting height ability from the bumper jack. The Lift-Matwww.desertrat.com
Lifts the wheel immediately instead of at the top of travel like lifting from frame, bumper or slider and the weight of the vehicle secures the jack against the tire/ rim, it can't fall to one side or back toward you as long as the vehicle doesn't roll. Makes a Hi Lift safe lifting all four corners.
