OEM Spray in Bedliner
Eatonpcat
Eaton Twp, Ohio
Anyone with the factory sprayed bedliner have this happening and can I prevent it from getting worse?
I would removed the bed liner in that area - scoring it with a box cutter may allow you to peel the bed liner up. Repair/sand the rust then have a shop shoot new bed line in that area/
If it’s not under warranty then I second this approach except I would just rattle can bedliner the patch area and hit it with white paint because I’m cheap diy and it’s just the corner of the truck bed
Probably what I will do, thanks for the response...Most likely take @Rockcrawlindude's technique of rattle can for the repair and keep an eye on, touych up again when it needs it.
Thanks for the ideas!
If it's the factory bed liner, then it's actually done in Mexico, where they are built. Then send it out to a local shop to do the bedliner.
I agree with Rockcrawlin. Easiest way to repair it. Might want to put some pore 15 on the bare metal first.
