not sure of the problem
will2022
I have a 2022 with 95k miles and it make a sound like a major air leak at extremely high pressure. when it dose this I loose power really bad and it seems to boiling the coolant out any help is greatfull.
Could be a stuck thermostat, check the coolant. Head Gasket is a likely suspect. Is the tail pipe pushing out white smoke, smell like coolant burning?
Probably a leak in the CAC system. Anything from a torn boot, cracked intercooler, or spit gasket. Low boost=excessive engine temperatures=overheating. Are you towing heavy when all this occurs? With that mileage on a 22 model year I’m guessing a hotshot truck?
