No Surround View & Guidelines?
Shocktrooper392
Hey guys, 2023 Ram 2500 PW Level 2 with 12.1 Uconnect.
Some time this week, my surround view camera screen went black and front & rear guidelines disappeared.
However, every single camera on the truck still functions individually. None of them have damage or are dirty. Tried slamming the tailgate a couple times (someone on reddit said it fixed their back up camera being black), to no avail.
Tried restarting Uconnect (holding power & tuner button together).
I've seen this issue posted on reddit a couple times but no where does anyone say what they did to solve it.
Any suggestions besides taking into dealer? Next thought is to try disconnecting the battery for a few hours tomorrow when I'm at the shop.
for s/g's, did you make sure the lines are enabled in settings? If not, if you have Alfaobd you can check if the module has codes....And try looking at the settings:
LIN Module Customer Programmable Features:
Rear View Camera Dynamic Grid Lines Enabled: Set
Vehicle Config Customer Settings Menu 1:
Rear view camera gridlines customer settings menu: Dynamic
But as you mentioned, see if disconnecting batteries will do it. But give the BCM some time to reconfigure. I read another thread where they replaced "Tailgate Harness/Jumper and powerlock/camera cables"
Thanks for all the info. I did check the settings. Everything is turned on its just not functioning like it should.
I don't have Alfaobd, but I wonder if it's something my shops Matco Maximus 4.0 could see if there's any fault codes.
If I don't see anything on scanner then I'll try battery disconnect and see where it gets me.
