brv10
has the scoop
If not delivered in 30 minutes your truck is free?On second look, they stole the tracker from Domino's and changed the color to red. If only it was as fast.
It's vague when it comes to codes but it's something for you guys to go byI guess I am not sure what someone in B or C would see?
Now, if only they let YOU be the delivery driver and give you a tip for doing so we'd be in business.If not delivered in 30 minutes your truck is free?
As long as it is FREE, FREE, Brofessor, Brotaterchip will take itIf not delivered in 30 minutes your truck is free?
For a second, I thought you were scheduled the same day you ordered!!! I had to zoom in on that oneMine is accurate now, too! Thanks for this info. Now I have something to do 20 times a day! Haha!
Second bar, you won't get an EL until after the 4th bar.What would come first - an equipment listing sheet on the website or the second bar on the order tracker?
Ah ok. Thanks. I mistakenly thought that the equipment list came before build.Second bar, you won't get an EL until after the 4th bar.
Correction, you won't get Window Sticker until after 4. You'll get the EL just as it's being built, so the 3rd bar.Ah ok. Thanks. I mistakenly thought that the equipment list came before build.
I've been wondering if there's something I could do with the site. It would probably make sense to start with a new sheet. If I did that, I'd probably do something along the lines of:This is even something that could be used by/for Officer Sanchez for tracking the trucks in the spreadsheet, but would require adding LastName into the spreadsheet, and any other columns to store information from this if desired.
Someone that is ordering a '23 will have to fill your shoes for the 2023 Order Spreadsheet. It's like the Olympics, you're passing the torch to the next generation.I've been wondering if there's something I could do with the site. It would probably make sense to start with a new sheet. If I did that, I'd probably do something along the lines of:
1. form to enter VON, last name, email, username
2. form populates a hidden sheet to keep last name and email private
3. use the hidden sheet data to check the new site
4. Parse the truck picture URL to figure out what features the truck has
5. send email updates once status is hit. Also check for EL/WS at certain status
6. etc etc
If I were planning to order a 2023 I'd spin something like that up. But my wife hasn't exactly agreed to that yet.
