Really like the setup! What fuel can is that?
How did you fasten the plywood to the bed? I see in the YouTube video you have thumb screws, what do they screw into? Great idea BTW. Thanks
How do you like the seat covers? How are they holding up so far?
Depends on how heavy you're towing, if pretty heavy the early oil change isn't a bad idea, if moderate then I'd go with a normal interval or slightly shorter. If you don't like the warning light you can always just reset it, I go by miles anyway, not the dash indicator.Just got back from a month long, about 3500 miles, trip towing the trailer. Had it in Tow/Haul mode. At 2500 miles, the change oil warning came on. Of course, I changed the oil, but I did leave the Tow/Haul off the rest of the trip. Got better mileage and the use clock went at half speed. Hmm...
Only a about 7300 pounds, rarely over 65, mostly at 55 to 60 mph and in 7th gear. I don't care much about the message that pops up. It was one cycle, change soon, then next was "required". It just surprised me that is was so soon. I was guessing 4K. I'm going to drive the same, but without Tow/Haul engaged and see how long it takes. I am guessing that the algorithm ticks faster in Tow/Haul mode regardless of the actual duty cycle.Depends on how heavy you're towing, if pretty heavy the early oil change isn't a bad idea, if moderate then I'd go with a normal interval or slightly shorter. If you don't like the warning light you can always just reset it, I go by miles anyway, not the dash indicator.
