Grapevine suggests that you're stuck with it - for now. I don't like it either. If the map is full screen, the "where to" stuff won't prompt. If you're set for split screen, it'll pop up every time the system is restarted. Logic?I have my 12.1 set up with the map on top and radio on the bottom. Has any figured out how to get the map to open to the actual map instead of the "where to?" Screen?
It's not a big deal to swipe each time, but if I don't have to...
Yeah, I find that annoying too. Oh well.I have my 12.1 set up with the map on top and radio on the bottom. Has any figured out how to get the map to open to the actual map instead of the "where to?" Screen?
It's probably my only gripe about the 12" screen. Have researched it and found the same as Burn'n Oil said.I have my 12.1 set up with the map on top and radio on the bottom. Has any figured out how to get the map to open to the actual map instead of the "where to?" Screen?
I can't get nav to open on the lower screen while having carplay and the waze app running on the upper screen
