gimmie11s
I've used Zone Offroad in the past, and they make great stuff. I've also used a plethora of the spacer blocks that sit on top of the spring (or coil pack depending on application). Nothing wrong with those either.
This time around I went with Bilstein springs/struts because I didn't like the way the strut extension is mounted on these trucks. I got 2" of gain out of it, and I'm sitting completely level. I don't like the idea of the truck squatting when I load it, but that is a side effect of leveling. A few hundred pounds doesn't do anything, but if your loading a few thousand, it'll sag. I ordered some airbag helpers for the rear to be able to air up as needed and take the squat out for the times I load heavy. I've done those before with other leveled trucks, and it works out pretty well.
The Bilstein kit (46-268655) was $487 and an adjustable track bar (I got for free) are typically about $150 - $200.
Install can be done in your driveway with basic hand tools and 2 jacks. Nothing special needed to get it done.
Sexy!!!
