MyOutdoors
Im in the process of hooking up my rooftop led strobe. Im utilizing factory aux 1 to power strobe and aux 2 as a monetary switch to change patterns. When I turn on aux 1 the strobe will flash on once the turn off. Aux 1 is set to latch.
Aux 2 does nothing as of now.
When im wiring the 3 wire to aux 2 I went black to ground, yellow to power and left red capped thinking it was only used to power the original controller. Does the red and yellow need to be spliced together then connected to aux 2?
