led interior map light hype flash
2021DAMRAMMINIT
Ive got a 2021 RAM 2500 & I swap the original center map & dome lights with LED. Can somebody PLZ help me with this. Ive used ALFA OBD to change settings for my new reflective led swap. Im sure I can this 1, as well but I want to be 100% sure!! THX for any help I receive...
Shout out to Jimmy 07 for helping me on the last project
If you're asking about just swapping in LEDs for the interior lights then all you do is take the old bulbs out and put in LED bulbs. A bunch of us have done it and it makes a huge difference. You just swap bulbs, no Alfa OBD needed.
Check out this thread:
I think the OP is asking for help with his new led’s flashing when he starts the truck? Mine do this as well.
Could be. I was not understanding what was actually being asked and still don't. I don't have that problem since swapping in LED bulbs. Maybe try a different brand? Sorry I'm not more help.
Sorry 4 the confusion, but yes its the new led bulbs in the map light. They come but then they start to hyper flash. The crazy thing is that the dome light doesn't HF @all. I assumed that could b fixed using Alfa... Didnt really want 2 buy another or try different brands. If possible ... Thx 4 ur imput
I understand now. I have not had this happen at all. I did not use the lasfit brand that I linked to. I used the autogine brand from Amazon. I'm afraid alfa obd won't help either but someone else may have some advice. I used these and have had no issues:
AUTOGINE 12 Piece White Interior LED Lights Kit for 2019 2020 2021 Dodge Ram 1500 2500 3500 Super Bright 6000K Interior LED Light Bulbs Package + Install Tool https://smile.amazon.com/dp/B08RDHW...t_i_RGBM13NZD38AQ5398Y7P?_encoding=UTF8&psc=1
There not real expensive so If I don't get some more advice. I will give them a shot. Thx 4 ur help
To my knowledge some led bulbs don’t draw the correct amount of voltage so it causes this, from experience on older vehicles I’ve changed to a higher quality CAN BUS bulb or added a resistor.
