I replaced my stock bulbs with LEDs and the difference in light output was very noticeable. I have yet to have an issue with other drivers flashing me or anything.I've had good luck with headlight revolution in the past .
The problem is you don't have projectors. It's going to be a little more light for you. And a ton in other drivers eyes.
At a minimum leave the low beams stock. I agree the halogens are terrible but led's doesn't seem to be the fix. I put I light bar on my last two trucks and left headlights stock.
I'll follow this thread then. Cause the halogens are useless in these trucksI replaced my stock bulbs with LEDs and the difference in light output was very noticeable. I have yet to have an issue with other drivers flashing me or anything.
I had a loaded 2019 1500 sport with the LED headlights- which were excellent lights. I was really concerned moving into a tradesman with the halogen lights. After putting in new LED bulbs, the light output is very similar. Overall its a non-issue now, the headlights are more than adequate.I'll follow this thread then. Cause the halogens are useless in these trucks
I sell a 6k.12000 lumen set. $50 a pair shippedCan anyone recommend a particular brand of aftermarket LED swaps for high/low beams and reverse lights for my Tradesman? I've been looking around, but there's so many companies that are making them.
I’m not sure if your question was directed at me, but I have been running the morimoto 2 stroke 3.0 for a while now. They mimic the halogen bulb filament placement perfectly and are very bright.Can you be more specific on what models you used? Did this mimic the halogen behind that reflector? I would like the hi/lo and backups myself, maybe soon even the tail/break lights and the ambers
Those are impressive prices on the Lasfit Bulbs. The Website is a little misleading as well. Over $700 for a complete set of LEDs? At those prices just as well purchase RAMS LED Headlights. The Lasfit Bulbs are identical to several other companies marketing these Aftermarket LED's, but at a more expensive costs. Research shows me several companies marketing these somewhere around $30 per set of Low or High beams depending on which position you're interested in swapping. About $60 for a set of 4. (2 Low and 2 High Beams).I used Lasfit Bulbs in mine.. https://www.lasfit.com/products/201...s~dz_the-whole-package&variant=31739709784148
You’re replying to a thread from 5 years ago.Those are impressive prices on the Lasfit Bulbs. The Website is a little misleading as well. Over $700 for a complete set of LEDs? At those prices just as well purchase RAMS LED Headlights. The Lasfit Bulbs are identical to several other companies marketing these Aftermarket LED's, but at a more expensive costs. Research shows me several companies marketing these somewhere around $30 per set of Low or High beams depending on which position you're interested in swapping. About $60 for a set of 4. (2 Low and 2 High Beams).
