LASFIT Interior LED Light Upgrade for lower trims I did
BighornHDRam
I could not find any links on this so here is one for you guys with Bighorn and Tradesman trims with incandescent interior light bulbs.
I got tired of not being able to see anything in my center console with the horrible incandescent lights so I decided to do something about it. I ordered 4 LASFIT L-T10 2 for the overhead console and 2 for the footwell lights and a 2 pack of LASFIT L-44MM for the dome light but you only need 1. These work with no canbus issues
Dome light took about 3 minutes to install, climb in on the driver side back seat and with a small screw driver there is a small tab opening on the left side to slide it into and pry the tab out and then it will come out and hinge open towards the passenger side. I had to pinch down the tabs a bit to get a tight fit around the ends of the L-44MM,
Footwell lights took about 4 minutes a piece as you lay on you backside and pull off the white dust cap and remove the OEM bulb with a pair of needle nose pliers very carefully clamping down on it while pulling it out, then just install the new one into the slot.
The overhead console you open the the sunglass pocket and there are 2 8mm bolts you remove, then beside them are 2 tabs that you push and the console starts to pull down from the front windshield and at the back of the console there are 2 tabs that go into the headliner. As it was hanging I removed the 2 sets of wires connecting it to the truck and moved it to the bench.
After removing you have to gently pry with a very small screw driver and remove the whitish cover plate over the light and you have to work around the edges and it will pop off (be gentle), then from the backside of the console you can push the incandescent light bulb out of the metal tabs that hold it and the chrome piece may fall out as well but you can put that back in before you install the new LASFIT L-T10. If the Chrome piece has fallen out reinstall, install new bulb, install whitish cover plate and repeat for other bulb. Reinstall overhead console and enjoy.
I changed mine out to lasfit shortly after buying my truck last year. Those lights definitely make a huge difference in light compared to factory. Why every other light on my bighorn is LED but the interior are incandescent is beyond me.
Did this mod on my Tradesman today as well, literally night and day difference.
Question for anyone with them, where are the footwell lights located. My truck doesn’t have them but curious if the wiring is there……….couldn’t tell when I tried to emulate Hudini and crawl up under the dash
On my Tradesman, I did the dome lamp and will wait on the map lights for now, but I am with Grateful Dad...where are the footwell lights?
Crap.....mine doesn't have them either. Guess I have some spares now as I ordered (4) :confused:
hmmmm......interesting. I definitely would be interested in knowing if there's any wires already run.
Me too!
"hmmmm......interesting. I definitely would be interested in knowing if there's any wires already run."
Thanks for the write up, just did this the other day. Huge difference !
Glad I could help you guys out as I was sick of not being able to see anything in my truck. I did not know the Tradesman trucks did not have the footwell lights, my bad.
Went to order the bulbs - but wanted to clarify which L-T10s did you order? I don't see the "L" portion popping up when perusing LASFIT?
