or is it the Indian?
(It's a shooting metaphor)
Probably running street pressure, but they did say when it’s hot the sand gets alot softer.
Please no. The guy is a ****ing idiot with no sense of safety or professionalism.Love that channel
Wow, did we watch the same thing?Please no. The guy is a ****ing idiot with no sense of safety or professionalism.
I didn’t watch, I’ve seen enough of that YouTube channel.Wow, did we watch the same thing?
Is there Always an element of danger, yes. But using proper methods and equipment it can be mitigated so the recovery can be done reliably with very little risk.By nature, recovery tends to be sketchy.
I cut my teeth wheeling an XJ so i like that channel. That dude has been snatching everything out of the sand with an XJ for years. I’ve seen him pull out trucks, campers etc.
I haven’t done much sand wheeling so I’m not going to make too much fun of the truck owner but I’m guessing he just lacked a little experience. Education is expensive.
I fully understand where you’re coming from because they portray themselves as recovery professionals but in reality they’re just goofing around. This is where the issue lies.Is there Always an element of danger, yes. But using proper methods and equipment it can be mitigated so the recovery can be done reliably with very little risk.
There was literally a video where one of them got underneath a vehicle in a sinkhole and then started shoveling.
They have a lot of followers because it’s entertaining, but these people see it and think it’s the right way to do recoveries.
I am a big proponent of safety and carry tons of gear (now) I didn’t always have the right gear. I have definitely put myself in some sketchy situations and had to do sketchy sh** to get home. But I don’t pretend that the sketchy methods were the right way to do things.
One of the worst scenarios I was in prompted me to buy a lot more gear. We were wheeling in a group of 3 and one XJ snapped a track bar (stock) but we found one in town. Now we just need to get to town. On the way to camp, my other buddy broke his rear driveshaft U joint and had to winch up a trail when his winch broke. So now it’s me and a winchless FWD XJ. Still on the way back to camp, I’m on a narrow pass and the side of the trail gives out and I roll three times into the woods, down the hill off the trail, wrapping vines around my rig. I had 94’ of steel cable and a snatch block but it wasn’t enough.
To right myself, i have to do the unthinkable and connect a snatch strap to the winch line as an extension.
Hell yea it was dangerous but that’s what we had to do at the time.
We still had to pull the plugs and un-hydrolock the motor after it was rubber side down again.
Ordered synthetic winch line, winch rope extension and a bunch of other stuff when I got home.
Disclaimer for those that need a disclaimer: do not try this at home. Steel winch line can whip and cause injury and snatch straps store kinetic energy. A failure here would have been very bad.
View attachment 21415View attachment 21416
So out of curiosity, does your beast hop on the sand? Do you do anything to stop the hop? What do you air down to?The old axiom "do as I say not as I do" is often what happens on the trail when not prepared or things get really hairy. I am guilty. I have run a lot in sand. Glamis and sandy areas of the Anza Borrego desert will get you up to speed fast. It is easy to get stuck if you don't know what you are doing. Sometimes even if you do
Here is a pic of me yanking a guy out at Glamis. I only had one stretch strap but several non-stretch straps. Hooked together they worked great. A towing company tried to get him out and couldn't. They tried with two lifted Power Strokes hooked up with chains (gads!) and then with a huge truck on 44s (they blew the beads LOL). They stopped by my camp since I had left a note on the truck saying I could get him out. They came back to watch. Single pull and I got him out. In front of me was a sand highway and then a large sand hill I had to climb to get him to the sand highway. The tow company learned something that day. They also charged the guy for just showing up.
Fun times!
Thanks for the reply! I went from a 2010 1500 to a 2019 2500 and I will admit this is a whole new best. I do love the truck, but the hopping on the back when she is unloaded is rather crazy. I think airing down is going to be the way I go!I haven't had my 2020 out at Glamis yet. I haven't had a problem tooling around the desert though. I didn't have much hopping in my 07 with the Carli setup. If you didn't ease into the throttle it would hop a bit at the start of a hill. I would usually run 16psi in the back and 18 psi in the front but I sometimes would go lower.
I also use to run with two spare tires mounted in the rear of the truck. A little weight in the back helps.Thanks for the reply! I went from a 2010 1500 to a 2019 2500 and I will admit this is a whole new best. I do love the truck, but the hopping on the back when she is unloaded is rather crazy. I think airing down is going to be the way I go!
