Correct me if I'm wrong but with my 2023 2500 I understand the follow:
The regular TPMS system requires the tires to be within 20% of the placard values (60 and 65 on my truck). If below, like when I air down, I get the alert that stays there until I fill above it. Helpfully the truck does the flashers and a honk when I reach that, assuming it's in Park and on. I usually don't even have to drive much, if at all.
The fill assist is off by default, and in the menu system. I haven't quite figured it out, but I thought it should beep at me if I lowered the pressure to set values. And it has two presets, but I can't figure out how to select one or the other.
As I understand it, it should beep as I air down and reach the setting.
Also, as I understand it if I turn off the ignition and turn it on again I'm back to regular, non STFA system. Perhaps I accidentally did that, not sure.
So my question is how do the presets work? how do I select one or the other?
