Jnrcarson
I live in Idaho so yeah it gets cold. Truck sits in my well insulated shop.I assume you dont get cold winters then?
I have had great luck with the NoCo products. I have the booster pak and tenders on the truck and my Honda Accord.can you expand on why that one is better?
Oem batteries used to set the standard. Heck, old batteries in general spoiled us. Nowadays they supposedly don’t use virgin lead as in the past. Combine that with the much higher electrical demands of vehicles and you get the picture.I ordered a new truck in 2004 with the H.O. diesel. My batteries lasted 17 years in that truck! I only replaced them because i thought the motor was beginning to turn over a bit slower than normal when cold starting. I can only hope I get half that out of my 2021!
Buy cheap you get cheap, my NOCO 4k had no issue starting my second gen in -30 with 15w40 oil in the sump…. Spend the money buy one NOCO, when on sale the 4k can be as low as 230$ CADIf you invest in a jump starter definitely get 2. There are plenty of Youtube vids on these trucks where 1 isn't enough. One on each battery at same time will usually get it done. I have 2 cheap GOOLOO GT4000S rated at 4k amps which is what the top NOCO model offers. They're usually on sale on Amazon for about $100 with a lot of good reviews and even tested on RAM 3500 with multiple jumps before recharging. Whatever model you get, get the carrying case too and you can keep it in the truck. The case keeps them fairly insulated from the heat/cold.
Do you plug the NOCO to the main battery (left) or Aux (right)? I’m assuming leftIf my truck is going to sit more than 2-3 days I plug it into my NOCO Genius 5.
I like the NOCO Genuius models because they stop applying charge voltage when the batteries have a 100% SOC and will start charging again as needed. Cheaper tenders won’t do that and can easily overcharge your batteries.
Connet to the driver's side on the BMS connector. Both batteries will get equal amount needed since they are in parallel.Do you plug the NOCO to the main battery (left) or Aux (right)? I’m assuming left
