I just picked up a new to Me 2022 3500 Dually with 71K, build is 8/2, after having 24 hours with just shy of 400 miles if interstate and city I am getting 12.3 mpg. doing 70 on interstate got 12.8 around town getting 12.3. had a heavy ranch hand bumper on it and I installed the OEM bumper this morning. Check engine light came on today P2459. It is in regen the last few intown trips and seems to want to really go. when not regenning before it seems to be slow off the line and begin to pull at the end of each gear then drop and pull again.
Did you get any sort of warranty with the rig? P2459 is regen frequency too often, which is not a good thing. It take a lot of regens in a short time to get that code.
Also Code P203F. I filled tank with 3/4 in a jug before it over flows. the gauge showed 3/4 full not empty, "Stuck float"?
Tank can either be overfilled or the level sensor covered in DEF crystals. There is no float in the DEF tank and if you overfill the tank it can give that code.
