Hemi versus 7.3
Colorado isn't that far away, just a few days driving at a moderate rate. Not offering 91 octane fuel in CO is just dumb. Surely it is needed for turbo charged engines ? Engines with variable cams ? Sound like a nanny state issue vs technical issue TBH.
Far enough, since it's not needed here for the vast majority of customers. 91 octane fuel is available though 40 miles south on the highway over an 11K feet high summit. Our local fuel pump is at a low 5,643 feet elevation with 85 octane only gas and diesel. Our three Ram HD 4x4's (gas and diesel) run it with zero issues.
Here in CA, I would be starting at sea level with 91 octane and driving up to 6K ft and have essentially an empty tank. Then if I refill it with the low octane fuel available at high altitudes, then I would be driving back to sea level with crap gas. No thanks.
It is very simple. Either don't drive to high altitude places or if you do, don't fill up with low octane gas once at a high altitude if you are going back down. For the rest that live at high altitude and seldom go to low altitude locations, "crap" gas works just fine. 85/86 octane is equivalent to 87 at sea level.
I’m glad your truck is serving you well but 9,000 pounds it’s a lot.
I towed an 11k tag with my '21 RAM 1500 over Monarch Pass to Colorado when my POS '22 Cummins broke again. I was truly surprised how well it towed power wise but the trailer definitely was pushing the truck around. I installed a heavier sway bar on it and a VERY good anti sway hitch.
Running 55 I got just at 7 mpg, also better than expected. The only issue is I had to back down because engine oil temps were really pushing it. The 5.7 is considerably stronger than I ever would have guessed. My assumption is the 6.4 is much better.
Towed our TH yesterday with a neighbour's 7.3 gasser Ford. It has WAY more power than the old VE 12v we used to have or the 7.3 diesel.
Decisions, decisions, gas or diesel? Ford or RAM?
A 1500 doing that regularly will not last. Lol.
Post pictures of whatever route you choose.
I still vote 2026 Cummins.
If you’re going to tow often, a gasser simply is an inferior option.
Superior until you run out DEF in the middle of nowhere and the engine derates. But the sea of torque a diesel provides is glorious. My last diesel was a GMC Sierra AT4 1500 Dmax. Hwy MPG unloaded was 24, towing was 14, a 42% drop in efficiency. With my 2500 Hemi, towing the same trailer I get 10-10.5 MPG. Unloaded I get 13MPG. A drop of 20% efficiency. Food for thought. While your MPGs may be higher with a diesel, it is not necessarily more efficient than gas.
Don’t run out of DEF. Be an adult and plan ahead.
Mmm… 500 miles on a 50 gallon tank or 700 miles on a 50 gallon tank? Such a hard decision.
If you can’t budget DEF at 300-400MPG, then you probably shouldn’t be towing a trailer at all.
You’ll run out of fuel 4x over before needing a jug of DEF. It’s a non-issue.
As far as efficiency goes, diesel has a higher BTU than gasoline, making them inherently more efficient based on that number alone. So yeah, they are much more efficient.
On paper, but look at real world numbers. Also, DEF is a guessing game. I’ve been there done that. DEF usage varies wildly, ambient temperatures, load, road conditions, elevation etc. I had times when I left our house towing our camper and the DEF gauge said 2000 miles left, just to scream add DEF 300 miles down the road while towing. Look at Fuelly and you’ll see that most Ram Diesels average 17MPG. The 6.4 averages 13. But that’s a crapshoot since you can’t tell how much of that is towing mileage vs unloaded.
What I posted was my experience with diesel not being more efficient while towing than gas.
Derate may be much longer than the 150mi countdown by the time your truck shows up, not sure where that legislation is at currently…
Ignore the gauge and crunch the numbers.
Towing heavy, I have yet to dip below 300mpg on DEF consumption, and I cover 50-60k miles a year. If you can’t manage that, then you surely can’t manage fuel stops, which also happen to sell DEF. It’s a non-issue. The tank holds roughly 5 gallons, plan accordingly.
Diesel simply carries more energy per gallon, and is inherently more efficient. It’s science. Simply is a better platform for towing.
I can guarantee you that I can keep up with any diesel as far as getting there at the same time. It’s biology. Your 50 gallons of diesel cannot outrun your bladder. So that point is good on paper but not in real life unless diesel drivers wear adult diapers. Both diesel and gas will far outrun your bladder.
What?
“Let me find something to validate my point even though I’m wrong…” LOL
What?
Let’s do math. What is your average MPG unloaded? Now do towing. Let me know the difference.
Ladies and Gentlemen, the first person in the world to say that gas is more efficient at towing than diesel. LOL
Answer the question. On my post I posted my real world experience with a diesel truck and gas truck towing the same camper. But you choose to insult instead.
By the way, when I purchased that camper I owned a 5.7 gas Ram 1500. I towed the camper several times over many miles and the average towing mpg was 14. Unloaded I got 17.5 mpg average. I traded that truck for a diesel thinking I would get killer mileage towing and, wait for it, I got exactly 14 mpg average. Unloaded I would get 24 mpg. That is a much bigger drop vs the 5.7. That is what I said diesel isn’t necessarily more efficient. But go on, continue being an AH.
Your logic is flawed. The diesel still has a higher average mpg even if it drops more as in your example.
Out of the three vehicles I owned, a 3.0 diesel, 5.7 hemi and 6.4 hemi, the biggest drop in MPG was the diesel while towing the same camper with similar weight including gear in very similar situations and mostly at 65mph. It went from 24 to 14. That’s 10 mpg less. The 5.7 dropped 3.5 mpg and the 2500, 3 mpg.
Granted the gas engines average much less MPGs unloaded than the diesel. When loaded the diesel dropped the most. It isn’t hard to understand.
