Thanks for sending this! A quick scan of this document indicates I should be running at 55 psi with my tires (315/70 R17 Load Range E), since the lower psi seems to be for different tires. But that was just based on skimming the document; I will spend more time reading through it later.
Ahh... that's a slightly different tire size than you originally indicated.
A 315/70R17 LRE holds the same weight at 50, 55, 60, and 65 psi thanks to a TRA limitation on 17's to 3195lbs. When you read the chart the C, D, and E under pressures indicate the max pressure for that load range. I.E. all 3 load ranges can support the same weight at 35 psi, but only LRD and LRE can run more than 35 psi and support more weight.
