Hemi Column Shifter
el_barto
Has anyone converted their 2019-2024 2500 Hemi with the shifter dial to a column shifter? Now that the 2025+ models (both Hemi and Cummins) all have the electronic column shifter with the ZF transmissions I’m thinking a retrofit conversion might be possible?IMG_2594.jpegIMG_2592.jpeg
Its going to take some work....and money.
This is not exaclty your situation- but it shows what parts you would nee for the column shift.
That’s an older truck with a cable linkage. Since it’s electronic now, it is less likely the whole column would need to be replaced, and certainly no cable to replace. Though, there may be differences in the wiring.
I’m pretty happy with the rotary dial, mostly just curious if it’s more feasible now that they have a column shift for the ZF transmission.
