New here- looking for some help, if someone would be so kind?
Problem:
I replaced the active shutter assembly on my truck, (along with the connector) due to a small front end collision. I cleared all codes and ran the "Replaced Active Shutter" routine with my scan tool.
I'm still getting an - " U11E9 DTC - Lost Communication with AGS" code after a few key cycles.
Does anyone have access to the wiring diagram from that unit to the PCM? I'd like to make sure the wiring is good before I contact the Active shutter vendor to etell them the new unit appears defective.
Thanks in advance
John
Problem:
Thanks in advance
John
