Heated steering wheel
Lteberle
2022 2500 Laramie (700 miles)-heated steering wheel won’t stay on. Push the button, it lights up for second or so and turns itself off. Go into unconnected screen and turn it on their, same thing.
Off to the dealer……-4 this morning would have been nice to have.
I found out if I just shut off the truck and restart it, it’s works again.
It’s only happened 2 or 3 times in the last couple months.
I haven’t contacted the dealer yet. Figured they wouldn’t find anything anyway since it works most of the time.
That's what mine was doing but now I've got nothing
If it’s under warranty, I’d get it in. I’d would be pretty easy to find the problem when it’s not working at all.
My 2022 had/has the same problem. Dealer had it in the shop for a few days and could not reproduce. Go figure. Hopefully it’s not an issue down the line but at least it’s documented now.
I had several issues with my Raptor, took videos with my cell phone. Then the stealership stopped telling me they couldn't reproduce it. I've done this about 5 different times, hard for them to disprove at that point. Had them replace every issues that way
Sent from my SM-G986U using Tapatalk
My 22 with the 12.1 has been doing the same thing with the heated wheel, I have found it only happens when I remote start my truck. I took it into the dealer while it was not working and had them take a video of it and document it. They had me bring it back in and replaced the steering wheel but that has not fixed the issue and has not worked twice since replacement. They are waiting on an answer from Star on what to do next.
Update on my heated steering wheel, back in February 2022 I had the steering wheel replaced at 1800 miles on my 2022 that seemed to fix my issue with it immediately turning off after 1-2 seconds. Fast forward to October 2022 and the issue had returned, so they once again replaced the steering wheel but that did not fix it, so next on the list they replaced the clock spring which has seemed to have addressed the issue so far.
So if your UC5 is having heated steering wheel issues have them look into the clock spring.
Did the clock spring fix work? My heated steering wheel has started to have the same issue.
I have the same issue, started a few weeks ago. The seat heat comes on automatically when cold enough but the heated wheel shows a warning and will not work
Same scenario with my '22 Longhorn. Everything I read points to the clock spring. If its this common, it should be a recall. I have to spend the money (6 months past the 3 year/ 3600) on it to have it fail again. I have changed out clock springs in th epast. They are not too hard. BIt not a cheap part either.
