hazard button
hawkuh60
I am looking for a part number for the hazard button switch bank from a 2500. I would like to see if I can use the left and right buttons as an aux switch in my 1500 ram. thanks
I am looking for a part number for the hazard button switch bank. I would like to see if I can use the left and right buttons as an aux switch in my 1500 ram. thanks
You may have better luck on the 5thgenram forum with 1/2 ton questions but there is a P/N thread here you can try out to see for a part number if no one can get back to you here
I should of said the hazard switch bank from a 2500. I m looking to see if it will work in a 1500.
Are you going to make them mechanical somehow or hack the LIN bus?
Those are digital pulses on the connections...
Well I guess based on your comment probably not I was hoping they were a little more mechanical and I could use the left and right button as an auxiliary switch seems like such a waste to have what could be two buttons that do nothing in my 1500. I don't know why Ram can't get it together it can't be that hard to build in factory auxiliary switches in every model or at least making an option.
I know not 100% factory, but just put in S-pod or Trigger.
There's a thread on 5thgenrams for using an overhead pod for the s-pod stuff.
There's a guy working on aux switches for 5g 1500s. He's close to being ready to market with oem switches. I thought maybe I could make a use of the hazard button panel. I assume it's probably part of the 12 in screen.
I pages through a bunch or parts lists on Mopar but couldn't find it.
I know @Jimmy07 and some members over there have been working to find a way to get the factory HD AUX switch panels working in the 1500's, but I think he's been focusing more on getting UC5 retrofit working.
Is this something else?
