Hi guys,
I thought I would save some time and have my local B&W installer put in the gooseneck hitch. He screwed up royally, the hole is 1/4" off, and he used a 4" hole saw instead of a 3-1/2". My idea for a fix is to have a welding shop cut out a square around the hole and weld in a patch panel with the right size hole, in the right location, so the bed is properly supported by the recess on the hitch assembly. What precautions should I take with welding in the panel? Do I need to disconnect both batteries or anything else to protect the electronics on the truck? I planned on having a bedliner installed so I'm not too worried about the looks of the patch, but I will have to raise the bed and prime the underside of the bed after the patch is welded in.
