Gas gauge
Diputs
I filled up today (hemi 31 gal tank) and my needle was on E and the range estimate was 15 miles. I was only able to put 26 gallons in the tank. Based on my average mpg, I should have had a little over a gallon left with that range remaining and needle that low. But with a 31 gallon tank and 5 gallons actually still in the tank you would think the gauge would be higher and show about 1/6 full and ~60 mile range. Is my gauge off or is this normal?
I had similar happen recently, but instead of 15 miles remaining, it switched to "Low" on the DTE.
I've run the tank pretty low, but that one time the DTE switched to "Low" was the closest to empty I have run it, and I could only get 27.453 gallons in. I am generally in the 22-25 gallon range filling up.
I think while the tank is 31 gallons, there are breather hoses, sensors, and room for temperature based expansion, etc. built in, which reduce the usable capacity of the 31 gallons.
Thats just how they are these days its like they give them a bit of a reserve
Per my AlfaOBD dump, the low fuel warning is set to 8%, empty is set to 2%.
Interesting...
It's normal for the gauge to read empty prematurely.
It's to prevent you from allowing it to run out of gas.
It's also intended to keep the fuel pump submerged and cooled. Habitually running the tank to empty or near empty will result in premature fuel pump failure.
