FML Wednesday : P2459
Units
South Ms.
Anyone have any idea how many times I can clear this code before I get a derate? First one popped this morning, yes I’m aware of the TSB for this and my truck falls into that time frame, will be calling the dealer as soon as they open but right now my TT is 1 1/2 hrs from me and was getting some work done and I have to go pick it up in the next couple of days.
That code should not cause a derate, worse case you may get a power reduced derate if the filter reaches a certain soot load, but you will not get a 5mph derate for soot loading, the 5mph derate is for DEF/NOX issues.
I also wouldn't clear the code if you are planning on taking it to the dealer, you may not be able to get it to set again in a reasonable amount of time.
@superjoe83 so I guess since there is a check engine light on it won’t go into a soot based Regen? Or will it? Debating on going and picking up my camper.
It should still regen with the P2459, but if it gets to the point where It says "exhaust filter full power reduced" you will have likely set code "P242F DPF Ash Accumulation" which inhibits regens because it thinks the filter is full of ash.
At that point you would have to reset the DPF timers to allow a parked or active regen. If the soot load comes down during regens I doubt that you will have a problem, especially when towing
If you elect to visit your dealership on this then please let us know, @Units! We're here to help and would love if you gave us the opportunity. Send a private message any time.
Hannah
Ram Cares
How much city driving/idling have you been doing?
What does the dash soot gauge show?
Maybe put some 6400d in it and go get the trailer. The 6400d and towing should help clean the DPF out.
Towing made no difference, driving was mostly my daily commute sprinkled in with a few short trips here and there. Pulled my TT 1 1/2 hours and it made zero difference. Bought several different air filters as that was the only I changed other than my oil. Bout to post my findings in relation to the air filters in the air confusion thread.
My 22 is on the fritz as well.
Got my first 24hr regen cycle in after a handful of shorter cycles, and followed that up with a 6 hour interstate trip. Figured that if driving habits were to blame, that would have blown things out good and proper.
Well, now I’m loaded up at 80% DPFRG% at only 8 hours on this cycle (6 of which were highway driving at 83mph, and most of the loading occurring very rapidly between 40 and 80 percent). This definitely is a failure in the system.
