So just ordered a set of Falken Rubitrek tires for my Power Wagon. Been doing a lot of research on 35" tires and decided on these.
I didn't see many reviews on these tires so I will be the guinea pig and try them out. I heard a lot of guys liked the wildpeaks and this has a very similar tread pattern. The side walls are not as aggressive as the wildpeaks. A few guys are raving that these did much better than their K02s which was one of the tires I almost decided on. Plus the 55,000 mile warranty isn't bad. Got a great deal on 4 installed for $1051 out the door. Tires are scheduled to be installed 1/7. Once installed I will post a few pictures, and review after I get a good amount of miles on them.
| Item Number | Tire Size | Load ID | Ply Rating | Service Desc. | Approved Rim Width (in) | Measuring Rim (in) | Overall Diameter (in) | Overall Width (in) | Revs Per Mile | Tread Depth (/32in) | Tire Weight (lbs) | Max Load Single/Dual (lbs) | Max Pressure (psi cold) |
| 28070963 | LT315/70R17 | E | 10 | 121/118S | 8.0 - 11.0 | 9.5 | 34.6 | 12.7 | 604 | 20 | 72.8 | 3195/2910 | 65 |
