Crusty old shellback
It may be hard to tell from the photo, but this is beyond what I'd expect and beyond any other truck that I've owned. This is my first solid front axle truck, so possibly there is something there that I'm not aware of, but otherwise I cannot imagine that RAM would consider this normal. The left front tire is identical to the right from a wear perspective. Googling this problem with RAM HD trucks brings up many hits about alignment so I'm hoping that a trip to the dealer will take care of it.Again looks pretty normal to me especially for a right front tire. Most roads are crowned for water runoff which makes people compensate to the left causing light outer edge wear. The Firestone tires that come stock are not known to do anything well (even wearing) anyway. Personally I would not be concerned.
Yes. Decimals. 0.33 total toe, not 33.0Heres the print out.
Jetrinka....thanks for not only the feedback, but for taking time to set for zero on your own truck!Truck certainly drives much better. Had to adjust the drag link a couple times to center the steering wheel to my liking but overall it seems much better mannered. Still have to compensate some for road crown but it doesn't feel as laborious due to the front tires not fighting each other anymore.
Overall very happy with Thuren's toe suggestions!
Just to confirm when I bring my truck to the dealer, zero degrees is the low end of RAM's spec's, and I should request the tech to set mine at zero. Correct?
Go to the Thuren website and read their article on RAM straight axle trucks. Very informative. Then print out the page with their specs and take it with you and ask them to use those specs. Worth a try.Jetrinka....thanks for not only the feedback, but for taking time to set for zero on your own truck!
I've done them with just a tape measure and a weight on a string with the vehicle sitting on level ground.Wouldn’t count on warranty covering it.
I did my alignment with a magnetic angle finder and a tape measure. Ymmv
No judgment at all. Rotating the tires on these is quite a job.I've done them with just a tape measure and a weight on a string with the vehicle sitting on level ground.
But I'm old and wanted the tires rotated and it set to 0.
I think the tow thing is BS, trying to hide something. Unless you have a really heave trailer that you bumper tow.
But I haven't towed anything and at 3200 miles, the out side had enough wear that I could see it.
I'd say its worth it to just spend the $100 and have a good independent shop do the alignment to the Thuren specs and be done with it.
