Engine RPM/Shifting
Rgpracer
Well, something that i don't like but it just might be the norm (this will be hard to describe).....when i take off from a stop, rpm rises, tranny changes gears but seems like when i go from second to third....forth, it acts as though it changes gear, then changes again and then lugs down terribly....i have to give it more throttle to shift up again so it won't be lugging....man, hope you guys understand, I'm not good with how to describe it.
Is this normal, is there anything i can do, is a throttle program an option?
Thanks
Torque Converter unlock-shift-relock.
Run it in Tow Haul if it upshifts too quickly.
Have you had any of the performance TSB's performed?
Also sounds like maybe you baby it. Drive it like you stole it. The trans learns your driving habits so if you babied it during break-in, it's gonna shift like a grandma's Oldsmobile.
