BlueOx2500
Is this overfilled? Had my dealer do the oil change recently and it was clear when I checked it after drive home and it was hard to tell the level but I suspected it was overfull then. Now about 500 miles on it and the stick looks like this. Doesn't matter if I check it cold after sitting all night, 5 mins after warm up or 30 mins after warm up it reads above the safe mark. I believe the surface of my garage is level. Is this a problem big enough to warrant draining some out? I don't have reason to believe there is fuel in the oil at this point. This seems to be a semi-common issue when searching the internet and searching these forums I could not find anything substantial. Thanks
