Locating EGT Sensors and Normal Temperature Ranges on a 2021 6.7L Cummins
EGT Sensor Locations
On the 2021 6.7L Cummins engine, the Exhaust Gas Temperature (EGT) sensors are typically located in the following positions:
EGT1: Near the turbocharger outlet.
EGT2: After the Diesel Oxidation Catalyst (DOC).
EGT3: Before the Diesel Particulate Filter (DPF).
EGT4: After the DPF.
EGT5: Near the Selective Catalytic Reduction (SCR) catalyst.
Temperature Ranges
Monitoring these sensors with your Edge Insight CTS3, you should see the following normal temperature ranges:
EGT1: 400°F to 1200°F
EGT2: 300°F to 1000°F
EGT3: 300°F to 1000°F
EGT4: 200°F to 800°F
EGT5: 200°F to 600°F
For accurate readings and secure sensor connections, using high-quality components like the Cummins ISL/ISM/ISX 21021850 V band clamp is recommended.
Monitoring these temperatures can help ensure your engine operates within safe limits and can alert you to potential issues before they become serious problems.
Temperature Ranges
