Wheelz
Anyone here running 37x1250 on a dually? If so, can I have a measurement on width from outside tire to outside tire puurty please? I'm getting a flatbed made and need to figure out how wide to make the bed for coverage.
I'm going to 22's but I'm still waiting for my wheels to be made and couldnt provide the fabricator the track width. Anyhow, I found a truck with the exact specs I'm going to use. ..it's 102" track width for 37x1250x22. Thanks
Here is mine with 11.5 with Nitto 37"
I ended getting a set of American Force w/ 37x1250 with oem offsets and 10 lug conversion with .5 spacers inboard. The track width on these went 106" I believe the 5500's have a totally different axle and are stock 10 lug. IMHO, I think any aftermarket wheel you get will be beyond 102 for your axle. Heck on the stock 17" I was running a 265/85 with a 2" spacer in the middle and i was already 102. With the stock offset and these tires..I was rubbing the leafs.Did this end up 102”? Can you let me know the offset of your outside rear wheel?
Have a 5500 coming and trying to stay less than 102”…
Thanks!
Damn you...
NEED MORE PICS!!
Looks like stock wheels.. which spacers are you running?
2"Absolutely love it. Which spacers?
I see you used stock wheels with 2” rear spacers. Did you need to lift the front any? I have 2022 DRW with rear air and my truck is already sitting basically level so i would not be interested in further raising the front and i do like the 11.5 37’s you have.Here is mine with 11.5 with Nitto 37"
Truck has air ride as well, but I did lift the truck with a 3.25 Carli pin top kit.I see you used stock wheels with 2” rear spacers. Did you need to lift the front any? I have 2022 DRW with rear air and my truck is already sitting basically level so i would not be interested in further raising the front and i do like the 11.5 37’s you have.
Thank you! But do you know was the lift required to prevent rubbing on front? Did you ever run the tire setup before the lift?Truck has air ride as well, but I did lift the truck with a 3.25 Carli pin top kit.
How much room in between your tire bulges? Looks a little tightHere’s my 22 Laramie on 37/12.50/20
I also have rear air and did the 2.75 Carli leveling kit and added 1” bag spacer and 1” axle spacer.
What size are your wheels? Trying to figure out front and rear offset for the fuel blitz with the same tire size setup you are running.Here’s my 22 Laramie on 37/12.50/20
