If you want to eliminate the damper from your equating, put on the 5100 and be done with that cheap and quick.
It really improved the wheel-feel over stock imo…
Indeed…For myself it isn’t the associated cost when the premium stuff needs servicing/rebuilding, it’s the propensity for it to fail at inopportune time. Like, three days into a two week elk hunt…had enough of that with Fox so KISS.yep i would recommend this for most people, unless you have money to set on fire and i can help with that too.
Turns out I have slight movement in the drag link so hope to avoid high dollar fix with adjustment.
Would the recommended fix be to replace the drag link or track bar?
Not under warranty. What specifically would need retorqueing?
Whichever/whatever comes on a Raptor, pfffft afiac.I had Fox 2.0 shocks on my 3500 for 500miles, 3 of the 4 blew out. I would stay away from any Fox entry level products i have heard a number of defect issues. I have fox 2.5 elite shocks on my Gladiator and could be happier.
This is what I’m referring to. There seems to be some small movement where the silver colored threaded piece goes into the bar. Should that be torqued as you suggest? Or are you speaking of something else?
I have had to straighten my steering wheel before so I’m good with that adjustment. It is the one that connects to the pitman arm that I’m referring to.Are you replacing the drag link? (Bar from pass knuckle to steering box.) Or Tie rod? ( bar between the 2 knuckles.)
If drag link, you WILL need a fork or puller to get it out of the pitman arm. Ask how I know.
But you can center the steeringwheel yourself, no need for alingment.
If it's the Tie Rod bar, then yes, you will need to aling the Toe.
I just replaced both of mine and went with Apex. Their Tie rod ends are replaceable and greasable, unlike the factory one.
Pictures in my build thread.
