Dual alternator usage
Mark M
I am getting a 3500 with dual 220A alternators.
I want to charge lithium batteries in the truck bed. I’d like to draw as much power as possible.
In my current truck I only pull 30A to charge a smaller battery pack. The cables are wired from the chassis battery back to the house batteries.
Can I do that with the factory dual-alternator setup? I guess I’m asking how much continuous current I can safely pull through the factory wiring and also how much continuous current can I safely pull from the dual alternators.
Is there a better way to do this?
I’ve got the alternator power curves but that shows maximum power vs alternator RPM. How much can I use for this one giant accessory.
The HAPP is rated to 300A.
Chassis ground is only good to 50A.
Entire thread is a good read but HAPP info is in post #7.
With the factory 7 pin wiring you can use a 18A DC-DC converter.
As mentioned the HAPP is good for 300A. Large negative loads are supposed to be grounded to the block.
How big of a DC-DC charger are you planning?
120 Amp
No issues with that load.
I would take power from the HAPP, run it thru a fuse, and back to the DC-DC charger. I’d also use an aux switch, if you have them, for the remote on/off of the charger.
