Disable cornering fog lights?
Kross
I'm embarrassed to post this question considering how many times it has been asked but I can't find a definitive answer.
I've purchased and installed the Baja Squadron Sport fog lights in my '22 Power Wagon. Because they're so bright, I'd like to disable the feature where they turn on when low-speed cornering & turn signals.
Can this be done with any of the coding tools?
Can this be done with a Switch-Pro, bypassing the standard fog light wiring?
I've seen people mention using AlfaODB but others say it doesn't work.
I'm basically looking for any function that disables all auto-on fog light functions.
Thank you!
Don't feel bad...I didn't know this was a thing. So all 2023 HD have this feature by default?
At this point Im most likely going to repurpose these Baja SSs as ditch lights and revert to the factory fog lamps.
I thought there was a setting in the menu for this , ill look tomorrow maybe I'm wrong
I'm still looking for a solution to this as well. Even if I could turn them OFF when I use my turn signal. While stopped, I'm blinding oncoming traffic when I have my left signal on, so I tend to just turn without a signal which I'm sure I'll eventually get a ticket for. @Jimmy07 any new thoughts?
Here's the only post I've seen with a possible solution
Yeah, wasn’t able to get this to work on mine.
