Dirty filter after 95%???
Rgpracer
Ok, so, is this considered dirty?
The front filter usually doesn't look dirty if the rear is doing it's job.
If it was a CP3 truck, I'd still run it. With a CP4 why take the chance?
The filter change reminders are all based on miles.
It's always been my rear filter that looks the worst. The front filter usually looks good but I know from experience never chance it.
You DON'T change your front filter Max?
Mileage? Hmmmm.
Thanks Brutal
I can see you missed what I said. I said why chance it. I always replace both front and rear at the same time. The particals that you can see aren't the ones that will destroy things. It's the ones you can't see.
I figured it was me not understanding what you said....thanks Max.
Not sure what a dirty one should look like rider.
a bit darker than that, but that's simply telling you the rear filter is doing a great job.
when I had a cp4, I changed them both at the same time.
The front is great but thats normal with 2 filters when i lose the CP4 ill go back to doing 2 rear filters to one front filter
