dinks
Dinks
hey all,
I have 2020 2500 tradesman. I recently added some new wheels. I still have the factory tires on the new wheels. they are set at 65 psi. a buddy told me when your not towing to bring the tire pressure down to about 50 psi to save on tire ware. i was wondering if anyone else has heard of that
I run 55 front and 45 rear when not towing a heavy load a long distance. More even edge to edge tire wear and smoother ride is a benefit to doing so.
OK thanks much appreciated
No problem, welcome to the forum. One thing I failed to mention is the TPMS May have to be recalibrated depending on your model unless you don’t mind the dash warning light being on.
I has les schwab recalibrate the TPMS and it didnt work
AlfaOBD and the AEV procal snap are 2 good options for recalibration.
I run 45/40 in my power wagon when running empty. But I've changed tires to BFG KO2 35s.
Best bet is to look up a tire inflation chart for your specific tire and see what pressure they recommend for your truck weight. Most will be down around 35 to 40 PSI. 65 is for when the truck is fully loaded to max weight. even then, it's a bit high.
Depends on tire load range 65 is not enough for a loaded E range tires at max gvwr….. OP the best way to do it with your truck unloaded is to do the chalk test…. And unloaded +- 500lbs on my 19 T man 2500 i run at 60 it gives the best wear pattern
