Diesel Particulate Filter Gauge , Is It Working
<div class="bbWrapper">It continue to be amazed at how poor the service can be directly from a dealership. Neither the tech, nor the service manager / advisor saw anything wrong with that routing? Unbelievable.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 1989" data-quote="Brutal_HO" data-source="post: 276327" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276327" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276327">Brutal_HO said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I guess my point was, the tech probably had an oh sh*t moment when he couldn&#039;t put the cable into the standoff because it was on the wrong side of the hanger and just said F* it. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> Yeah, quite possible. Either way I’m sure he got an earful.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 20814" data-quote="Blythkd1" data-source="post: 276302" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276302" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276302">Blythkd1 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Please let us know if you notice any negative impacts. I&#039;m paranoid to take mine in. I figure there&#039;s no way they&#039;re going to fix something without screwing up 2 more </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>If everything with your DPF is functional currently, there should be no additional issues after the sensor is installed. You’re getting an additional 12 month, unlimited mileage warranty on the DPF in the event the sensor does detect internal DPF failure, you can get the whole unit replaced under warranty. It’s likely to take each person some time to get the sensor as it’s on the same restriction as all the other recalls. One sensor every 7 days. Might as well get on the wait list. If you don’t get the sensor now, you’ll have to get it eventually if you have your truck worked on in the future. Any Future work that requires a PCM flash will result in a permanent DTC for lack of communication with the sensor since it won’t be there. The current versions of the pcm software from today onward will contain the programming for the PM sensor and module. There won’t be any backward compatibility with the software flashes.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 15983" data-quote="mbarber84" data-source="post: 276332" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276332" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276332">mbarber84 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> If everything with your DPF is functional currently, there should be no additional issues after the sensor is installed. You’re getting an additional 12 month, unlimited mileage warranty on the DPF in the event the sensor does detect internal DPF failure, you can get the whole unit replaced under warranty. It’s likely to take each person some time to get the sensor as it’s on the same restriction as all the other recalls. One sensor every 7 days. Might as well get on the wait list. If you don’t get the sensor now, you’ll have to get it eventually if you have your truck worked on in the future. Any Future work that requires a PCM flash will result in a permanent DTC for lack of communication with the sensor since it won’t be there. The current versions of the pcm software from today onward will contain the programming for the PM sensor and module. There won’t be any backward compatibility with the software flashes. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Although I didn&#039;t really want to, I contacted the dealership a few months ago and they said they would call me. Still waiting. Maybe I&#039;ll just drag my feet until the truck has another owner<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" /></div>
<div class="bbWrapper"><blockquote data-attributes="member: 20814" data-quote="Blythkd1" data-source="post: 276356" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276356" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276356">Blythkd1 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Although I didn&#039;t really want to, I contacted the dealership a few months ago and they said they would call me. Still waiting. Maybe I&#039;ll just drag my feet until the truck has another owner<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" /> </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>It’s going to take a long time to get these recalls completed when they can only order one part every seven days. I would imagine more than a few trucks will be in the hands of new owners long before the recalls are completed.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 16919" data-quote="OuterUB" data-source="post: 276363" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276363" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276363">OuterUB said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> What&#039;s a DTC ? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>An easy Google search would tell you it stands for <b>Diagnostic Trouble Code</b></div>
<div class="bbWrapper"><blockquote data-attributes="member: 2087" data-quote="John Jensen" data-source="post: 276365" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276365" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276365">John Jensen said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> An easy Google search would tell you it stands for <b>Diagnostic Trouble Code</b> </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Fair enough. Much obliged sir. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" /></div>
<div class="bbWrapper"><blockquote data-attributes="member: 16713" data-quote="AH64ID" data-source="post: 276330" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=276330" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-276330">AH64ID said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Yeah, quite possible. Either way I’m sure he got an earful. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>How many others has he done like that? I always look after someone else monkeys with my truck and usually end up finding something wrong. That was the case with CP4.2 recall and early 19 trans valve body recall.</div>
<div class="bbWrapper">I have been told by some that the missing sensor measures soot levels passing thru the DPF like if ithe filter was damaged or has a hole in it??? Something Calif wanted who wants to ban diesels altogether.<br /> What do you guys think?<br /> Thanks</div>
<div class="bbWrapper"><blockquote data-attributes="member: 31144" data-quote="mitchblankenship42" data-source="post: 281765" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281765" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281765">mitchblankenship42 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I have been told by some that the missing sensor measures soot levels passing thru the DPF like if ithe filter was damaged or has a hole in it??? Something Calif wanted who wants to ban diesels altogether.<br /> What do you guys think?<br /> Thanks </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>The sensor measures the amount of soot exiting the DPF and SCR. It sits at the outlet of the SCR chamber. It’s looking for excessive soot in the exhaust stream. The DPF is almost 100% efficient at trapping soot so theoretically nothing but a minuscule trace amount should be getting through. If the PM sensor detects more soot than what the calibrated threshold is, it trips a code for a failed DPF (cracked internally or a breach in the pressure vessel allowing sooty exhaust to bypass the system and exit to atmosphere)</div>
<div class="bbWrapper"><blockquote data-attributes="member: 31144" data-quote="mitchblankenship42" data-source="post: 281765" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281765" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281765">mitchblankenship42 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I have been told by some that the missing sensor measures soot levels passing thru the DPF like if ithe filter was damaged or has a hole in it??? Something Calif wanted who wants to ban diesels altogether.<br /> What do you guys think?<br /> Thanks </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote> <blockquote data-attributes="member: 15983" data-quote="mbarber84" data-source="post: 281770" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281770" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281770">mbarber84 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> The sensor measures the amount of soot exiting the DPF and SCR. It sits at the outlet of the SCR chamber. It’s looking for excessive soot in the exhaust stream. The DPF is almost 100% efficient at trapping soot so theoretically nothing but a minuscule trace amount should be getting through. If the PM sensor detects more soot than what the calibrated threshold is, it trips a code for a failed DPF (cracked internally or a breach in the pressure vessel allowing sooty exhaust to bypass the system and exit to atmosphere) </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>It does not measure soot, only NOx<br /> Selective Catalytic Reduction\DEF Process - When NOx reaches a certain level DEF is injected into the SCR to remove NO2/NOx. The NOx levels trigger the DEF injection and also determines the quantity of DEF.<br /> <br /> Trucks shipped without the SCR sensor are set to use a particular amount of DEF to satisfy the EPA (not California). When the sensor is finally installed the amount of DEF used should be less because the sensor will determine when and how much DEF is needed.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 2087" data-quote="John Jensen" data-source="post: 281775" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281775" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281775">John Jensen said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> It does not measure soot, only NOx<br /> Selective Catalytic Reduction\DEF Process - When NOx reaches a certain level DEF is injected into the SCR to remove NO2/NOx. The NOx levels trigger the DEF injection and also determines the quantity of DEF.<br /> <br /> Trucks shipped without the SCR sensor are set to use a particular amount of DEF to satisfy the EPA (not California). When the sensor is finally installed the amount of DEF used should be less because the sensor will determine when and how much DEF is needed. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Sorry John but your information is wrong. <br /> <br /> The Y43 recall installs the PM sensor that was not available at the time 2022 (and some 2021) trucks were produced. It does nothing for NOx, nor does it have any control over DEF consumption. It is simply a watchdog sensor that sits at the back of the emissions system and checks to make sure the DPF isn’t cracked or compromised and allowing soot to exit into the atmosphere. <a href="https://hdrams.com/forum/attachments/img_3690-jpeg.63458/" target="_blank"><img src="https://hdrams.com/forum/data/attachments/63/63458-794bca5cad4e3bdff41e90899fadc049.jpg?hash=eUvKXK1OO9" class="bbImage " style="" alt="IMG_3690.jpeg" title="IMG_3690.jpeg" width="337" height="150" loading="lazy" /></a></div>
<div class="bbWrapper"><blockquote data-attributes="member: 20814" data-quote="Blythkd1" data-source="post: 281776" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281776" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281776">Blythkd1 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Hmm. My recall notice says it&#039;s a PM sensor. Are you talking about the Y43 recall? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Yes, the Y43 recall. You are correct, the recall makes it sound like a DPF sensor. The truck is shipped without the sensor in the SCR. It has a sensor in the DPF. The recall installs the SCR sensor, referred to as a Particulate Matter Sensor</div>
<div class="bbWrapper"><blockquote data-attributes="member: 2087" data-quote="John Jensen" data-source="post: 281779" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281779" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281779">John Jensen said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Yes, the Y43 recall. You are correct, the recall makes it sound like a DPF sensor. The truck is shipped without the sensor in the SCR. It has a sensor in the DPF. The recall installs the SCR sensor, referred to as a Particulate Matter Sensor </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>The sensor is installed at the outlet of the SCR chamber, but does not measure NOx or have anything to do with DEF dosing or consumption. It’s there to count “particulate matter” which is soot. The only reason Ram was successful in getting CARB to sign the MOU and allow them to sell the trucks without the sensor in place was because the PM sensor had no direct influence on how the entire emissions system meets targeted PM and NOx standards. The system functions exactly as all other model year trucks do, with the exception that it doesn’t have the ability to check the emissions for excessive soot exiting. They were hedging their bets that the systems would function well enough for long enough that ram could obtain the sensors within the year or so and have them installed before any of the DPF’s started failing. That’s why when the sensors first became available again, they issued the Y43 recall to cab &amp; chassis trucks first, knowing full well the commercial trucks would rack up mileage faster than the pickups.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 2087" data-quote="John Jensen" data-source="post: 281779" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281779" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281779">John Jensen said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Yes, the Y43 recall. You are correct, the recall makes it sound like a DPF sensor. The truck is shipped without the sensor in the SCR. It has a sensor in the DPF. The recall installs the SCR sensor, referred to as a Particulate Matter Sensor </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Prior to the recall being completed there is one sensor after the SCR, it&#039;s a NOx sensor. After the recall there are two sensors past the SCR, a particulate sensor and a NOx sensor. As others have stated the recall has nothing to do with the SCR/NOx.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 23602" data-quote="Jay P" data-source="post: 281782" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=281782" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-281782">Jay P said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Prior to the recall being completed there is one sensor after the SCR, it&#039;s a NOx sensor. After the recall there are two sensors past the SCR, a particulate sensor and a NOx sensor. As others have stated the recall has nothing to do with the SCR/NOx. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Well that makes sense. I did not know that.<br /> I have to thank you and Barber for educating me as I was misinformed by a so called expert. I stand corrected. I was also told all regeneration and soot sensors were at the DPF, had no idea there was one at the SCR to measure any soot the DPF missed. I feel like a jerk for being so wrong. Learn something new every day. I apologize.</div>
<div class="bbWrapper">I&#039;ve had mine installed for a few thousand miles now. The system seems to Regen less and in a manner that makes sense. When I&#039;m towing it works it&#039;s way back to zero and pretty much stays there as long as it&#039;s highway. Around town not towing it slowly goes up. Also, regens have gone from 45 minutes to 25... APPROXIMATELY. Just my observation so far. Only hiccup I saw was first weekend we pulled a 10K camper to a dirt bike event about 4 hours away, zero on the DPF meter. Started up the truck cold Sunday morning, much colder out and right out of the field we were camping in was a long steep hill and it immediately went into regen even though the meter was still set at zero. That event was also immediately after getting the recall done. It&#039;s acted normal since, no complaints.</div>
