sstoner911
Stock exhaust tip?
The exhaust temps exiting are surely not 900 degrees.
To my eye it looks plausible. It appears that if the wind was extreme in the direction described, that the superheated gas was collecting inside the rear bumper as it blew sideways and back. Likely only took just enough of it before some of the thinner plastics caught fire and eventually the bumper itself. It appears the side of the hitch itself is discolored in the direction the exhaust would have come from as well. I believe it.
@RamCares
Any chance some carboard or some other sort of flammable trash, got picked up on the highway and wedged in the right (wrong) spot and your regenning hot exhaust ignited that? Another improbable but not impossible scenario. I've heard a few stories of trash on the highway getting wedged in the wrong spot near a hot exhaust and causing problems ranging from an annoying burning plastic smell in the cabin (Plastic bag melted to the cat on my grandparents car), to an entire medium duty truck going up in flames (Cardboard found it's way between the cab, body, and stacks).
Definitely a good thought.Any chance some carboard or some other sort of flammable trash, got picked up on the highway and wedged in the right (wrong) spot and your regenning hot exhaust ignited that? Another improbable but not impossible scenario. I've heard a few stories of trash on the highway getting wedged in the wrong spot near a hot exhaust and causing problems ranging from an annoying burning plastic smell in the cabin (Plastic bag melted to the cat on my grandparents car), to an entire medium duty truck going up in flames (Cardboard found it's way between the cab, body, and stacks).
Mine were in my toolbox in the bed. Definitely the wrong place this time.PSA for everyone.
CARRY AT LEAST one ABC fire extinguisher in your rig. I carry three in the truck, 2 driver side and 1 pass side, and two road accessible in the camper.
I actually find this very plausible in a “perfect storm” situation (no pun intended). Probably easier to let insurance comprehensive take care of it, and they’ll decide if they want to investigate far enough to go after the manufacturer for reimbursement.
It's the stock exhaust tip.Stock exhaust tip?
I definitely found reports of trailers getting trim melted while being towed from the regen process. I would never have guessed it would happen to the truck itself, but it was a unique driving circumstance with the sustained winds.There are some who pull 5th wheels who have claimed that the regen has melted trim etc under the cap around the bottom edge of the 5th wheel...most posts I have seen are from several years ago and Duramax owners...
Must be a common denominator but not that common.
With the trailers - I suspect this happens when the trailer is being backed in and the truck exhaust is to close to the corners(when truck is 45 degrees)of the trailers and perhaps left idling for extended period of time. All the melting seems to happen on the passenger side but this doesn't mean it happened while towing - its just to far away.I definitely found reports of trailers getting trim melted while being towed from the regen process. I would never have guessed it would happen to the truck itself, but it was a unique driving circumstance with the sustained winds.
Have your lawyer go after the administration that forced this kind of BS on manufactures to install this type of WorldWinds of BS to diesel trucks.
Fuel is injected. Not to clean the filter, to raise the exhaust temps.I don’t think fuel is dumped down our exhausts to clean the filter. I believe you are referring to different technology that our trucks don’t possess?
Injected into the cylinder, and burned there. As far as I know the only diesel that injects diesel into the exhaust post turbo is the (junk) caterpillars with the ARD head.Fuel is injected. Not to clean the filter, to raise the exhaust temps.
Active regeneration - is triggered when the DPF exhaust back-pressure reaches a certain back pressure point and is interpreted as 80% soot for the 6.7. Then the ECU initiates a fuel injection designed to increase the exhaust temperature in the DPF to over 662 degrees F in order to oxidize the particulate deposits. When completed, the ECU assumes a some small amount of residual soot and resets the value to 9%.
Not on these trucks its not injected into the exhaustFuel is injected. Not to clean the filter, to raise the exhaust temps.
