Nolapilot89
2020 RAM 2500 6.7l Bighorn 26,000 Miles.
So I've got the dreaded "Service DEF System see dealer" Indication. I am in MT, so the cold temps could play a role as all last week we were in the negatives. However for 2 nights I had it sit inside a heater hanger (set at 60F)for 12hrs, so one would think it would have thawed in that time. I also was under the impression that the tank had some sort of heating element to prevent it.
I called my local dealer, they told me they can't look at it until 2/14. thats over a month away and I only have 125 miles till 'Limp mode". Their reponse? "park it". wellllllll Its my only running vehicle so thats not an option. I called the next closest dealer that could see me this week is in Helena, and is about 80+ miles away. Would be cutting it real close. The dealer there told me to put it in the hanger again overnight and put a heater on it. However, this probably wont clear the message and will still go into limp mode.
So my question is this: has anyone ever been able to reset it? I've done alot of reading where people say to unplug the batteries for a bit, then touch the cables together (with batteries disconnected) and it should 'reset" things. However if there truly is an issue with the pump, this wouldn't be a fix. So on that note is there any way to test the pump? some what I could possibly disconnect the pump at the injector and just cycle it into an empty container?
What I'm going to try tonight is to pull it in, heat it up, Disconnect the batteries, and while I've got some time pull the DEF injector, clean it up if needs it, and maybe drain the DEF tank and refill with fresh DEF.
Any ideas? This is making that whole delete thing look like a pretty good option at this point.... The only benefit here is now I'm slightly more motivated to finish my 4bt bronco.
