John Jensen
I'm using Edge CTS3s on my two trucks and monitor the EGT temps. I thought I knew where each EGR sensor is located. I researched the forums to confirm my thoughts and found some conflicting data for the Cummins 6.7. Here's what I think it to be, but not sure.
Ram 3500 Cummins EGTs - In Question - need verifying
EGT1 is DOC Inlet (after turbo)
EGT2 is DOC Outlet
EGT3 is DPF Filter Outlet
EGT4 is SCR Inlet (Mid Band)
EGT5 is SCR Outlet
Can anyone verify the data for the Cummins?
EGT2 is DOC Outlet
EGT5 is SCR Outlet
